am 27.06.2026 17:24
am 28.06.2026 08:52
Depending on the status of your contract there are different ways. If you already are out of the 2 year minimum contract term you can simply cancel the contract with 1 month notice. If you are still within these 2 years you will have to report a move. Vodafone will check if the contract can be used at your new location and if not will terminate it by themselves. With you moving out of Germany that will happen, though you will have to provide proof of your move with the official deregistration certificate. In both cases don‘t forget to send back any Vodafone hardware.
The move process is covered here (in German): https://www.vodafone.de/hilfe/hilfe-zum-umzug.html
am 29.06.2026 16:35
Hi spatnaik,
great that you are reaching out early. If you are leaving Germany permanently around 31 August 2026, you can cancel your Vodafone cable contract early due to a special termination right, since the service cannot be used abroad.
Here is how we recommend you proceed:
First, inform us as early as possible about your planned move. Ideally, notify us a few weeks before your move out date.
For the cancellation, we usually need proof that you are leaving Germany permanently. This can be for example:
Once we receive your cancellation request together with the proof, we will review everything and confirm the termination date. In most cases, a remaining contract period of three months applies starting from the date we receive your documents.
Also important: If you have rented equipment like a router, you will receive instructions on how to return it after the cancellation.
The easiest way to handle everything is via WhatsApp. You can reach us via the buttons under this message. There we can check your contract directly and guide you step by step through the process.
We already wish you all the best for your move abroad! 🍀
Best regards,
Dave05
am 10.07.2026 22:32
Thank you for the response. Can you please let me know the whatsapp number as i don't find it.
am 10.07.2026 22:53
This isthe WhatsApp contact: 0172 1217212
am 11.07.2026 08:42
Thank u @Peter_Co
The quickest option is our link https://vod.af/VodafoneWhatsAppHilfe
