am 29.10.2025 16:11
Getting an activation code is a nightmare. I didn't receive it when the router was shipped. I requested it online twice, but still nothing. I can't believe I have to call for something so simple. What's the point of the Request activation code option if it doesn't work?
am 29.10.2025 16:19
If you got the router from Vodafone, you don't need an activation code. The router is activated. The only reason for a code is, if you use your own device.
If the connection is not usable, call the hotline and tell them, that "selfinstall has failed". In this case a technician will show up and fix the issue.
am 29.10.2025 17:53
nur zur Info:
der Aktivierungscode wird nicht benötigt um den Leihrouter zu aktivieren
