I will like to end my Vodafone Kabel contract
bukolaj
Hello ,
I have moved apartment and will like to end my contract as my new apartment have an existing internet connection
Can you tell me what I need to do .
I can also send you the Anmeldung for my new apartment
Thank you
4 Antworten 4
HausHelene
It is only possible, if existing contract is cable too.
In this case slower speed will be stopped
Peter_Co
Report the move to Vodafone (*not* by phone, for support in English use Whatsapp), Vodafone will check if your contract is available at the new location, then there are a few different scenarios:
a) your cable contract is not available at the new location: Vodafone will terminate the contract themselves.
b) your contract is available at the new location and the existing connection there is not a cable contract from Vodafone: your contract will move with you, you can terminate it at the end of the 24 month minimum contract time with a termination period of 1 month.
c) your contract is available at the new location and the existing connection is also a cable contract from Vodafone: VF will allow the termination of the cheaper contract as a gesture of goodwill.
Again, contact the support via WhatsApp:
https://forum.vodafone.de/t5/Vodafone-News/Dein-Kontakt-zu-Vodafone/td-p/1912292
OKay thank you for the explanation
I moved to an apartment with an existing internet so I will not be needing Vodafone
I will reach out on whatsapp again as I did not that but no response yet
Reaction time on WhatsApp can be days, requests are worked on in chronological order, so you need to be patient.
