Bridge Mode on own FritzBox
johnnyone
Hello,
I have a cable connection + telephone in Hessen and I use my own FritzBox 6690.
I would like to configure the FritzBox as "modem" only and connect it to my OPNsense firewall / router.
I see Max CPE=2. Can bridge mode work? I don't need the telephone. Can that CPE slot be used for the bridge mode?
So far, no success.
Thank you
2 Antworten 2
HausHelene
In Hessen works it only with a rent Fritzbox
Thank you for the answer and a bit less for the bad news 🙂
Could I use my own router with a TC4400-EU or Arris device?
