wifi connection problems
Gseob
Youngster
Youngster
Hello.
And first to say is sorry that I cannot speak German. I'll keep writing with English.
Recently I have problem with wifi connection.
It started since Nov 23 and first symptom was being slow. Then after Saturday it totally stopped.
Sunday and Monday it worked for a few seconds - how do i know? Cause i turned off my cellular data and only linked with wifi. In the morning i could find out that i've got several messages. Which mean while sleeping for sometime it worked. Now internet logo (2 arrow opposite direction are keep blinking)
To solve the problem i put on my IP address on the Chrome and checked the status. Also did the self connection test which given by UnityMedia. Please check the photo below.
It says i have some problem with broadband - broadband i guess.
I did every thing what i can do.
Reset. unplug the plug. wait for a few seconds than turn on. Etc..
Can I get advice for my situation.
Is it a problem with device (modem or router), or problem with cable (Coax cable), or problem with vodafone (the provider)?
Jens
Administrator:in
Administrator:in
Hello Gseob,
have you checked the W-LAN load on your computer? You should find this in the menu of the cable router. Maybe you can change it and have a more stable connection.
Then please write whether you have also tested via ethernet and where you are coming from (zipe code).
Regards
Jens
