Wifi stopped working
TiagoTrindade82
Good evening,
My wifi stopped working this afternoon. Internet and all the LEDs are OK. Only wifi is OFF. Can someone please support on troubleshooting?
Thank you.
Regards,
Tiago Trindade
Edit: @TiagoTrindade82  Moved in the correct board. Best regards Kurtler
Do a factory reset. Hold down the reset button for at least 20 seconds.
Best regards Kurt
