How do I order WLAN-verstärker?
voddafonne123
Hi, I wanted to order WLAN-verstraker to my cable internet but every time I go to Zu MeinVodafone nothing is happening. How can I order it?
5 Antworten 5
RobertP
do you really want to pay 3€ per month for a wifi repeater?
better buy your own one   😉
No prob, then which one would be the best for Vodafone Station? 🙂
are you realy shure that a repeater will solve your wifi problems?
voddafonne123
yes, I have the station upstairs and I need to strengthen the signal on the ground floor. Looks like a repeater would solve this issue, isn't it?
better you lay a LAN cable from the ground floor to the first floor and configure the repeater as an access point
