am 05.06.2022 09:28
No internet and router flashing blue light continues.
What is the problem please help.
Thanks
am 05.06.2022 10:46
Please see the logs.
INFO][LAN] 06-05-2022 08:03:20 LAN sending RA to ff02::1 [INFO][System] 06-05-2022 08:03:18 FSM---- Switch to Connect State. [INFO][System] 06-05-2022 08:03:07 FSM---- Switch to Connect State. [INFO][LAN] 06-05-2022 08:03:04 LAN sending RA to ff02::1 [INFO][System] 06-05-2022 08:02:57 FSM---- Switch to Connect State. [INFO][System] 06-05-2022 08:02:48 FSM---- Switch to Connect State. [INFO][WAN] 06-05-2022 08:02:48 WAN VDSL-DT has been stopped, please check your PHY link [INFO][LAN] 06-05-2022 08:02:48 LAN sending RA to ff02::1 [INFO][LAN] 06-05-2022 08:02:48 LAN sending RA to ff02::1 [INFO][WAN] 06-05-2022 08:02:48 Stopping VDSL interface OK. [INFO][WAN] 06-05-2022 08:02:48 Stop WAN 10 DSL Connection [INFO][LAN] 06-05-2022 08:02:48 LAN sending RA to ff02::1 [INFO][LAN] 06-05-2022 08:02:48 LAN sending RA to ff02::1 [INFO][LAN] 06-05-2022 08:02:48 LAN sending RA to ff02::1 [INFO][System] 06-05-2022 08:02:47 Starting HTTP redirect OK. [INFO][DNS] 06-05-2022 08:02:47 DNSMasq proxy server enable redirect [INFO][System] 06-05-2022 08:02:47 Stopping NTP Client OK. [INFO][VoIP] 06-05-2022 10:02:47 VoIP WAN down, no available connection [INFO][VoIP] 06-05-2022 10:02:47 Remove interface wan_id is 10,wan type 1. [INFO][VoIP] 06-05-2022 10:02:47 bud data ipv4 wan status -1,ipv6 wan status -1 [INFO][VoIP] 06-05-2022 10:02:47 Voice binding wan_id is 10,binding_1 wan_id = 10,stop wan_id is 10,is_ipv6 = 0,default_wan_id= 10 [INFO][VoIP] 06-05-2022 10:02:47 ===start stop voice wan [INFO][DNS] 06-05-2022 10:02:47 Internet DNS deactived. [INFO][LAN] 06-05-2022 10:02:47 LAN sending RA to ff02::1 [INFO][System] 06-05-2022 10:02:46 Starting NTP Client OK. [INFO][System] 06-05-2022 10:02:46 Sync up with NTP Server failed. [INFO][System] 06-05-2022 08:02:46 Stopping NTP Client OK. [INFO][VoIP] 06-05-2022 10:02:46 VoIP WAN down, no available
am 05.06.2022 12:32
Have you already had your installation appointment?
am 05.06.2022 19:23
Yes , it was working from last 4 months.
How to resolve can you please help.
Otherwise work from home will not be possible.
Thank you
am 05.06.2022 19:43
You will need to contact the hotline (in German language only) and ask for a technician to check the line...
am 05.06.2022 19:58
I tried but no help as I don't know German.
Also the internet works for 5 min and then doesn't it's continue the same way.
Any other way technical support I can get.
am 06.06.2022 14:20
Hi SachinR,
is it working now?
If not, please send us a PN with your customer-ID, the password and the link of this thread here.
Best regards
Heike
