Internet Connection Problem
feser
I have internet at my home. It doesn't work properly.
It has dropped several times this week.
Modem: VODAFONE-TG3442DE
Right now, I'm working from home and it is very important for me to have stable connection.
Can you check my internet connection?
Thanks
ERFD
Hello, feser,
the modem levels are very bad. Have any changes been made to the cabling? Did you check if the cable between modem and antenna socket is firmly connected? At the neighbours the values fit.
Best regards Fred
