High packet loss
Gelöschter User
Nicht anwendbar
Hello,
In the middle of the week (tuesday/wednesday I think) there were two major outages during the night that left the whole building without Vodafone internet for an hour or two (confirmed by neighbours). Since that there have been no outages, but the connection quality has degraded significantly. Right now, for example, I experience 10 packet loss on average going up to 20% occasionally. This makes it very hard to play videogames or even participate in conference calls, which is kind of important now that the majority of people work from home.
- Which product do you have?
  Vodafone CableMax 1000
- Which modem/ router do you use?
  Vodafone Station (as a modem) + own Wi-Fi router
- Do you use a rental device from us or do you have your own device?
  Both, I have my own router for Wi-Fi (in bridge mode) which is connected to the Vodafone station
- What error occurs?
  Extremely high packet loss (10–20%)
- Which browser do you normally use
  Not relevant
- What operating system do you have on your computer?
  macOS + Windows
- Start and duration of the fault
  Started a couple of days ago, not sure when exactly
I've attached the screenshots of mtr that I've launched 10-15 minutes ago. The packet loss has stabilised down to 8%, but at the start of the test it was close to 20%. I've started pinging my Wi-Fi router at the same time to show that the issue isn't related to my local wireless network and is on your side:
Martin59
Hi technocoreai,
Thank you very much for your answer.
Then please continue to observe this and if the problem does not occur anymore, then mark the solution here.
When this has happened, we will close the post.
Many greetings, Martin
7 Antworten 7
Martin59
Hello technocoreai,
please send me once your name, address, date of birth and customer number by PN .
Leave a short feedback here, then we will have a closer look at the connection.
Best regards, Martin
Gelöschter User
Nicht anwendbar
Sent you the details. I've also called the phone support line and have a ticket open, but if this is something that can be repaired remotely I'd really appreciate it.
Best regards,
Alex
Alexander01
Martin59
Hi technocoreai,
I got your message.
The colleagues will call you tomorrow and discuss everything else with you.
Gelöschter User
Nicht anwendbar
The packet loss was competely on Wednesday and I haven't had any issues since then.
Best regards,
Alex
Martin59
Hi technocoreai,
Gelöschter User
Nicht anwendbar
Everything's fine, thanks for the help!
