Englisch: Router keep resets itself
MichalTruhlar20
Hi, i have problem whith my router, in last 14days my router reset itself 3times, 2times this weekend. 1,5 moth back i got replacement router for my old one. But this new one just keep resets itself. Model is cbn ch7466ce.
9 Antworten 9
pRo-Marco
Hi MichalTruhlar20,
I can see some reboots over the weekend, but no reason for this Smiley (gleichgültig)
Can you see anything in the logs?
Kind regards
Hi, no i look everywhere but i did not find any reason why is this happening, it looks like random reboot, in one moment my internet just stop and few secods later modem is rebooting itself.  I dont know meaby some kind overload.
Hi, is there any chance how to get brand new router from vodafone, buy one or can i boost my tarif and get new router whith new tarif? Is there any of these options? Thank you
pRo-Marco
Hi MichalTruhlar20,
I can replace the router for free, okay?
Kind regards
Hi, and what model i will get? I dont wonth another used router like that i have now. Thank you.
Hello MichalTruhlar20,
usually it's the same modell but it may also be a different one, we cannot determine which modell will be sent.
Kind regards
Hi, i understand, but i definetly dont wonth same model, i read vodafone forum and some others forum and there is many people whith the same issues whith this model. So pls help me, is how i cant get brand new one, must i buy one, or whith diferent tarif?? Whith my luck if i get the same one i will end right here all over again.
Manu
Hi MichalTruhlar20,
i don't think the router we will switch has the same error.
if you want a brand new router, you are welcome to buy a device of your choice in a specialist shop. However, it must be certified for cable connection.
Best Regards, Manu
Hi, so i buy fritzbox 6490 cable is this model ok whith vodafone?  i hope it will work fine now.
