am 08.01.2020 15:04 - zuletzt bearbeitet am 21.01.2020 13:14 von Jens-K
Internet connection lost after few minutes. Both cable and Wlan. Nothing strange can be obsereved through Wireshark between device and router.
time=17.856 ms
64 bytes from 8.8.8.8: icmp_seq=928 ttl=55 time=22.365 ms
64 bytes from 8.8.8.8: icmp_seq=929 ttl=55 time=21.351 ms
Request timeout for icmp_seq 930
Request timeout for icmp_seq 931
64 bytes from 8.8.8.8: icmp_seq=932 ttl=55 time=40.707 ms
64 bytes from 8.8.8.8: icmp_seq=933 ttl=55 time=26.427 ms
64 bytes from 8.8.8.8: icmp_seq=934 ttl=55 time=18.160 ms
64 bytes from 8.8.8.8: icmp_seq=935 ttl=55 time=22.194 ms
64 bytes from 8.8.8.8: icmp_seq=936 ttl=55 time=21.491 ms
64 bytes from 8.8.8.8: icmp_seq=937 ttl=55 time=23.019 ms
64 bytes from 8.8.8.8: icmp_seq=938 ttl=55 time=23.650 ms
64 bytes from 8.8.8.8: icmp_seq=939 ttl=55 time=22.477 ms
64 bytes from 8.8.8.8: icmp_seq=940 ttl=55 time=20.290 ms
64 bytes from 8.8.8.8: icmp_seq=941 ttl=55 time=23.461 ms
64 bytes from 8.8.8.8: icmp_seq=942 ttl=55 time=26.898 ms
64 bytes from 8.8.8.8: icmp_seq=943 ttl=55 time=20.226 ms
64 bytes from 8.8.8.8: icmp_seq=944 ttl=55 time=23.717 ms
64 bytes from 8.8.8.8: icmp_seq=945 ttl=55 time=20.971 ms
64 bytes from 8.8.8.8: icmp_seq=946 ttl=55 time=22.980 ms
64 bytes from 8.8.8.8: icmp_seq=947 ttl=55 time=22.865 ms
64 bytes from 8.8.8.8: icmp_seq=948 ttl=55 time=22.062 ms
64 bytes from 8.8.8.8: icmp_seq=949 ttl=55 time=16.965 ms
64 bytes from 8.8.8.8: icmp_seq=950 ttl=55 time=21.470 ms
64 bytes from 8.8.8.8: icmp_seq=951 ttl=55 time=18.804 ms
64 bytes from 8.8.8.8: icmp_seq=952 ttl=55 time=20.578 ms
64 bytes from 8.8.8.8: icmp_seq=953 ttl=55 time=22.932 ms
64 bytes from 8.8.8.8: icmp_seq=954 ttl=55 time=23.778 ms
64 bytes from 8.8.8.8: icmp_seq=955 ttl=55 time=22.499 ms
64 bytes from 8.8.8.8: icmp_seq=956 ttl=55 time=22.860 ms
64 bytes from 8.8.8.8: icmp_seq=957 ttl=55 time=20.622 ms
64 bytes from 8.8.8.8: icmp_seq=958 ttl=55 time=23.377 ms
64 bytes from 8.8.8.8: icmp_seq=959 ttl=55 time=23.347 ms
64 bytes from 8.8.8.8: icmp_seq=960 ttl=55 time=18.689 ms
64 bytes from 8.8.8.8: icmp_seq=961 ttl=55 time=31.808 ms
Request timeout for icmp_seq 962
Request timeout for icmp_seq 963
Request timeout for icmp_seq 964
Request timeout for icmp_seq 965
Request timeout for icmp_seq 966
Request timeout for icmp_seq 967
Request timeout for icmp_seq 968
Request timeout for icmp_seq 969
Request timeout for icmp_seq 970
Request timeout for icmp_seq 971
Request timeout for icmp_seq 972
Request timeout for icmp_seq 973
Request timeout for icmp_seq 974
Request timeout for icmp_seq 975
Request timeout for icmp_seq 976
Request timeout for icmp_seq 977
Request timeout for icmp_seq 978
Request timeout for icmp_seq 979
Request timeout for icmp_seq 980
Request timeout for icmp_seq 981
Request timeout for icmp_seq 982
Request timeout for icmp_seq 983
Request timeout for icmp_seq 984
Request timeout for icmp_seq 985
Request timeout for icmp_seq 986
Request timeout for icmp_seq 987
Request timeout for icmp_seq 988
Request timeout for icmp_seq 989
Request timeout for icmp_seq 990
Request timeout for icmp_seq 991
Request timeout for icmp_seq 992
Request timeout for icmp_seq 993
Request timeout for icmp_seq 994
Request timeout for icmp_seq 995
Request timeout for icmp_seq 996
Request timeout for icmp_seq 997
Request timeout for icmp_seq 998
Request timeout for icmp_seq 999
Request timeout for icmp_seq 1000
Request timeout for icmp_seq 1001
Request timeout for icmp_seq 1002
Request timeout for icmp_seq 1003
Request timeout for icmp_seq 1004
Request timeout for icmp_seq 1005
Request timeout for icmp_seq 1006
Request timeout for icmp_seq 1007
Request timeout for icmp_seq 1008
Request timeout for icmp_seq 1009
Request timeout for icmp_seq 1010
Request timeout for icmp_seq 1011
64 bytes from 8.8.8.8: icmp_seq=1012 ttl=55 time=24.750 ms
64 bytes from 8.8.8.8: icmp_seq=1013 ttl=55 time=17.200 ms
64 bytes from 8.8.8.8: icmp_seq=1014 ttl=55 time=21.195 ms
64 bytes from 8.8.8.8: icmp_seq=1015 ttl=55 time=19.501 ms
64 bytes from 8.8.8.8: icmp_seq=1016 ttl=55 time=23.169 ms
@Artem_87 Edit: Moved from DSL to Cable. Regards, Jens-K
am 09.01.2020 10:31
Hi Artem_87,
welcome to the Vodafone Community!
Which modem do you use and what is the name of your tariff?
Did you check all cables and the DSL socket?
Regards,
Jens
am 16.01.2020 18:25
am 21.01.2020 11:04
So could you help please?
am 21.01.2020 13:30
Hi Artem_87,
I'd be happy to check your line. Please send me your name, address, date of birth and customer number in a PM?
Please let me know here again when you have sent the message.
Best regards
am 21.01.2020 18:21
Hey, sent the message. Thanks
am 22.01.2020 11:01
Hi Artem_87,
thanks for your data.
I´ve checked the connection and there seems to be a problem in signal quality.
I have forwarded an order to the appropriate colleagues for examination. You will be informed by SMS.
Best Regards, Manu
am 26.01.2020 17:27
Hi. My ticket is closed, but same problem exists. It's not fixed. Thanks
am 27.01.2020 17:58
Hello.
That's not normal. More then 2 months internet works from time to time, reason is unstable connection. I've got the notification via sms, that someone is going to fix the problem. Now status of my ticket is "closed". But connection is still unstable like before.
am 28.01.2020 08:44
Hello Artem_87,
I looked again: from the outside everything looks good by now. Therefore it makes sense here, the technician comes directly to you. Would that be okay? Can the colleague come with you to the house system? If so, please send me a phone number to make an appointment.
Kind regards
Moni
