1internet interruption
Leblanc
Apologies for the English, but my German is insufficient still. My internet went out at around midnight last night and now I only have a bliking power light on the modem. Anything I can do to fox this? A hard reset did nothing to fix the problem.
Jens-K
Hi Leblanc,
welcome to the Vodafone Community!
Which modem do you use? Did you check all cables etc.? Usually a restart helps. Please note that after a reset you have to activate your modem again.
If there is a known outage you probably find info here: Netz-Experten
Regards,
Jens
