I need to keep the same number after the contract termination.
Nota2033a
Hello,
I have cancelled my "Smartphone + Red plan" contract, and I need to make sure that I can keep the same phone number with me but not as a contract, and I need it to be on CallYa.
***cancellation affective 21-4-2021***
would you please confirm that.
thanks.
fine. then you can deposited the change to Callya  afterwards via the customer service. And from April 22.04.2021 you can use your previous number at Callya.
6 Antworten 6
Falkenhorst
have you already canceled the contract?
yes I did few days, through my vodafone portal.
thanks.
thanks a lot, I will try to make that asap :).
Matthes
Hey Nota2033a,
that will work
Should we leave the thread open and you will give us a short feedback?
Best regads,
Matthias
(Moderator)
thanks a lot 🙂
yes, I think this will be better for the others when they check this post.
thanks
