am 08.11.2020 10:30
I want to limit the amount of data usage my kid is using.
Can i set a limit of 1GB myself, or do i have to call the service line to achive that.
Thanks
am 09.11.2020 13:09
Hi @GwaiTsi ,
great that it worked with the setting. ![]()
The special security settings are designed for age-appropriate surfing - Internet breaks, subscription blocks etc.
These are controlled via the main card. ![]()
Best regards,
Michi
am 09.11.2020 09:23
Hi @GwaiTsi ,
here is a short explanation of how to use it in MeinVodafone App.
Red+ main card: Display and set Red+ data volume:
On the homepage of the MeinVodafone app, the main card owner selects the Red+ additional card tile. Here we display for each Red+ participant:
- used data volume
- Allocated data volume
By sliding the controller, the main card owner sets the data volume for each subscriber in 0.25 GB increments.
Save the changes with "Einstellungen speichern" - separately for each participant.
Best regards,
Michi
am 09.11.2020 11:27
Thanks Michi,
I didn't have the MeinVodafone app on the phone. I was trying to do on the web.
Installed the app and have set a limit per your instructions.
Regarding the "Kinder-Sicherheitseinstellungen" which appear under my child's card.
can i ask please;
1) is that meant to be run from my kid's phone or mein to set it up
2) what exactly does it do.
Thanks
am 09.11.2020 13:09
Hi @GwaiTsi ,
Best regards,
Michi
