change tariff to Red Internet & Phone 10 Cable
jie
Hello,
I would like to change my current tarrif from Red Internet & Phone 400 Cable to Red Internet & Phone 10 Cable. I subscribed at the end of last August, and was told that I can switch to lower speed options within one year. Could you please help me with this?
thanks.
14 Antworten 14
Anett
Hi yee,
please send me a PN with your data (name, customer number and address), then I will gladly check what we can offer you. Please report again in the post, if you have sent the PN.
Regards
Anett
jie
Hi Anett,
Thanks for the response. I just sent the data by pn.
Tina
Hello jie,
from 28th august 2018 you can change to the following tariffs :
Red Internet & Phone 32 for 29,99 €
 Red Internet & Phone 100 for 34,99 €
Red Internet & Phone 200 for 39,99 €
Kind regards
Tina
jie
ok Tina,
Please change to Red Internet & Phone 32, from 28 August 2018.
Thanks.
Best,
jie
Tina
Hello jie,
I'll note the change. You'll get a confirmation now. At the end of August you will receive the order confirmation.
Have you other questions?
Best regards
Tina
jie
Hi Tina,
That's great. Thanks!
Yes, in fact, I just moved within the city, and seems I cannot plug the cable in the new place, do I need to make an appointmeht for a technician for the move?
best regards,
Renjie
Nancy
Hello jie,
simply let us know about your move using our contact form. We will then check whether we can continue to supply you at your new address. If it should not be so, your connection must be terminated and we need in this case still another registration certificate as proof. You will send them to us as soon as you have registered.
Best regards
Nancy
jie
Hi Nancy,
ok. Thanks for the information. I just filled in the contact form.
Best regards,
jie
Nancy
Hello jie,
Your relocation notice has arrived and has already been processed. If you want to watch TV at your new address, you need a cable connection. In any case you need Vodafone TV Connect for 10,- Euro/month. For example, between Vodafone TV Cable for 9,99 Euro/month and Vodafone GigaTV Cable 1-12th month: 9,99 Euro afterwards 14,99 Euro/month. If you want, I can help you with that.
Best regards
Nancy
