Trying to change contract.
GauthamR
Digitalisierer
Digitalisierer
Hello,
Hope you are all doing well.
I have a Vodafone Kabel Red 500 contract currently, and my contract is gonna get renewed on January 2021, and I'm looking to upgrade / downgrade my tariff, I'm looking for a connection that has minimum of 50Mbits upload, and a minimum of 200mbits download, I tried to search quite a bit, and I found the 1000 Red Kabel is the only tariff that has 50mbits upload.
Can someone help me find a right tariff to upgrade or downgrade? Since my contract will be renewed soon, I would like to get this done quickly.
Best
Lars
Hi Gautham,
I think I have the perfect offer for you. I can offer you the Red Internet & Phone 1000 Cable for 49,99 Euro. The first 3 months even only 39,99 Euro. We can also schedule the change for 04/01/2021. The term is 24 months and there is a one-time charge of 9. 99 euros. Would that be something for you?
Best regards
Lars
11 Antworten 11
GauthamR
Digitalisierer
Digitalisierer
I put some thought again into it, and I decided to go with 250mbps plan with 25mbps upload speed, can someone help me change to this plan?
GauthamR
Digitalisierer
Digitalisierer
Hello, can someone help me downgrade to the Red Internet & Phone 250 Cable plan, please?
Moderators are quite busy in the moment, it can take a couple of days until they can take care.
Nancy
Hello GauthamR,
I am happy to help you and have looked at it right away. You can switch to the Red Internet & Phone 200 Cable rate for 39.99 euros/month on January 4, 2021. May I make a note of the change for you?
Best regards
Nancy
Hello Nancy,
Thank you very much for your response.
But I do not see a 200mbps plan currently on the tariff list, and the 200mbps plan has a very low upload speed, compared to the 250mbps plan which is for the same price, is it not possible to switch to the 250mbps plan?
Best,
Gautham R.
Hello Nancy,
I was also wondering, if 200mbps & 400mbps is the lesser option I have got, and since they have low upload speed, I would rather stick with a 500mbps or 1000mbps plan that has 50mbps upload speed.
What would be the highest plan that I can get for 50 euros/month? I know 500mbps is one of them, is 1000mbps also an option? Could you please suggest me the best I can get for 50euros/month?
Looking forward to hearing from you.
Best,
Gautham
Lars
Hi Gautham,
Best regards
Lars
Hello Lars,
Thank you for your response.
Yes this is something I would like to go for.
So this is 1000mbps download 50mbps upload, and the first 3 months its 39.99 euros/month, and then 49.99euros/month after that, and a one time upgrade charge of 9.99 euros, hope I got that right, if that's the case, I would like to go ahead with this offer and would like to schedule it for 04/01/2021 🙂
Please let me know what would be the next steps.
Thank you again.
Best,
Gautham
Stephan
Hi GauthamR,
you don't need to do anything else now. We have earmarked the change for 4 January.
On this date, your tariff will be changed and you will receive a written confirmation.
Regards
Stephan
