Transfer Kabel Deutschland Internet connection
Rushab
I am moving to a new place and the new apartment already has an internet connection. Is it possible to transfer my current contract on the name of a friend who is moving in my current apartment?
If yes, what is the procedure to do so?
If no, what is the procedure to terminate the contract pre maturely?
Thank you!
6 Antworten 6
freilinger
Mastermind
Mastermind
Hey Rushab,
til someone with more knowledge may help you, here a few tips.
It is possible to transfer your current contract to another person, but not if it's a cable contract.
Important informations about assumption of contract
For your cable contract use the service for relocation:
https://kabel.vodafone.de/meinkabel/meine_kundendaten/umzugsservice
Cheers
Thomas
Hi Rushab,
what kind of contract do you have (DSL or cable)?
Regards
Thomas
Rushab
Kabel
Stephan
Hi Rushab,
then it is as @freilinger has already described it. You can order the move to the new address for your connection.
Regards
Stephan
Hey @Rushab,
if you are wondering because you already have a internet connection at your new place, vodafone should realize this. I don't whats happening in this case, though. You might get the same conditions as in your current cable contract or you can cancel it.
Cheers
As the followers said: In some regions/towns u proberly got a calbe connect with ya rent-contract. If so, all will be fine. If not, its possible even. Just listen to the mods here. Help will go on.
