Returning router
Vladas
Sorry for a silly question, but I am not sure how to return an old router.
I moved apartments, and your colleague from a local office told me that I will receive instructions with the new router. Unfortunately these were not included, so I am not too sure how to send it back now.
Thank you!
Vladas
Tina
Hello Vladas,
I still have your customer data.
There has been a change of tariff. You also received new hardware for the new tariff. There should be a return slip in the package. If you no longer have it, please use the following address:
Vodafone Kabel Deutschland GmbH
c/o DHL Paket
Am Tower 222
90475 Nürnberg
Best regards
Tina
Which router is it? Cable or DSL?
Best regards Kurt
And is the old contract really cancelled?
Because a move does not mean that your old contract is cancelled - if it is possible, the contract will just move to your new address, so there is usually not the need to send back the old router as you'll need it in your new home.
Switching devices is only needed if you change technologies (e.g. switching from DSL (using the phone outlet) to cable (using the TV antenna outlet) or vice versa).
Tina
Hello Vladas,
c/o DHL Paket
Am Tower 222
90475 Nürnberg
Best regards
Tina
