Internet not working DOCSIS offline
amarulanda
Greetings
I installed my router following the instructions and all the lights are on. Both my cellphone and PC connect to the WiFi, but the internet does not work.
The  IP address says "DOCSIS offline". Does anyone know how to fix this?
I appreciate in advance your help.
Best regards,
Angela M.
Jens
Hey amarulanda,
sounds good and the college from the hotline hire a technician for you. That would have been my next move, too. The appointment follows in the next step to you.
Regards
Jens
7 Antworten 7
Jens
Hello Angela,
is it a new contract? Sometimes your own installation may not work.
You can sent me a pm with your customer data.
Regards
Jens
Hello Jens,
I just sent you the information to a pm.
Thanks
Jens
Hey amarulanda,
i can't reach the cable-router. Did you take the router off the power now?
You need a technician, if the connection hasn't been established yet.
I'd like to hire a technician and give your number to the appointment. Is that okay?
Regards
JensI
Hello Jens.
Yes, the router is on.
I want to make the appointment with the technician. I called today the curstomer service (08005266625) and they told me they were going to check what the problem is. But I really need to solve this issue since I need the internet for my work.
I appreciate your help.
Best regards,
Angela M.
Jens
Hey amarulanda,
Regards
Jens
ich habe die gleich peoblem. ich habe ein neue vertrag gemacht mit Vodafone aber in mein online portal uber kabelbox steht DOCSIS offline.
wie kann ich ein PM schicken oder havben sie eine email wo ich kan mein daten schicken.?
danke
pRo-Marco
Hi Atta007,
eröffne bitte einen eigenen Thread zu Deinem Thema. Wir kümmern uns darum.
Nach über einem halben Jahr, gehe ich davon aus, dass für den TE alles geklappt hat, daher mache ich hier zu.
