IPSEC Connections - WLAN cable router Vodafone Station Technicolor
ivanmarian
Hello,
Then please tell me how to enable the following ports:
500 and 4500 for IPSEC Connections on Vodafone
WLAN cable router Vodafone station
Manufacturer:  technicolor
Model: cga4233de
Otherwise I cannot establish Work form Home connection - these days is vital.
From theRooter Expert Menu is not available.
Thank you,
RobertP
normally it is not nessesary to open ports for an outgoing connection.
maybe your employer VPN server does not support connections over IPv6
Your employer should check the following settings:
a) maximum MTU 1432 Bytes (better go a bit below like 1400)
b) disable client IP check
-and-
as aleady written by @RobertP :
He should enable the IPv6 part of the server.
And as @RobertP already wrote: You do NOT need to open ANY ports on your side. If your employer tells you to do so, he or she simply does NOT understand how IPSec works and that it is NOT required in order for an OUTbout VPN connection to open INbound ports.
Manu
Hi ivanmarian,
in the user interface of the router you can adjust settings. Or do you use the router in bridge mode with your own router?
Best Regards, Manu
