Fritz BOX WAN with Kabel Deutschland
Sug
Dear Sir / Madam
    I have purchased a Fritz Box that comes with WAN connection. But for Kabel Detuschland connection I have a PIN and not LAN connection. Is it possible to connect this Router to Kabel Detuschaland?
mason
No, it´s not possible.
Your FritzBox is only for DSL/VDSL connection.
For Kabel Deutschland, you need a FritzBox Cable.
Modell 6490 with Artikelnummer 20002778
Or a FritzBox Cable 6590 or FritzBox Cable 6591 or a FritzBox Cable 6430
mason
Hallo Mason
    Thank you for your reply. I have purchased 7590 Fritz Box.  Do they have a cable version for this model?
Hello @Sug ,
No, all 73xx, 74xx, 75xx from AVM are DSL/VDSL modems.
The cable-router from AVM begins with 64xx or 65xx, but there ist one thing you have to know if you want to use the model Fritzbox 6490 cable. The free box has the "article number 2000 2778" ... only this one can use as an own router.
greets
Dieter
