am 18.02.2021 12:29
Is it possible to unlock my router so I can perform the update to the OS 7.20+ myself. My work has changed their VPN to a newer version which is supported in the latest Fritz OS but not one I currently have. It is thus much trickier to work at work without this.
I appreciate that you are probably field testing this so if you can put me on the beta or something instead that would also be an option for me.
Thanks,
Darren
am 24.02.2021 16:11
Hi DVInternet
Unfortunately, neither one nor the other is possible. Anyone renting a router from us will have to wait until we roll out the update. I am sorry that I do not have better news.
Best regards
Ida
