Compal CH7466CE port forward
Zoszkar
I'm using since a few years Vodafone Kabel internet with the Compal CH7466CE router. I have one Raspberry Pi and would like to connect to it via ssh. I have IPv6 connection and i can access my PI from IPv6 network but not from IPv4..
I wanted to setup "Hurricane Electric" tunel broker but no sucsess. The IPv4 ip address is not ICMP pingable.
 I couldn't find any option for ICMP in router settings.
Please help me, how can i access my device.
Thank You,
Hey @Zoszkar,
its activated! 🙂 Have fun then 😉
Regards
5 Antworten 5
Hallo Zoszkar,
you may use port forwarding if you enable the bridge mode and connect an own router to the LAN1 port of the Compal. You can find the bridge mode in the customer portal under Einstellungen -> Interneteinstellungen.
Kind regards,
Zoszkar
Thank you for Your answer.
I can't turn on the "bridge mode" because the "Homespot Service" is enabled. When I want to turn it off, I get this message:
"Lieber Kunde, Sie haben den Homespot-Service hiermit ausgeschaltet.
In ca. sieben Tagen wird diese Änderung wirksam. Während dieser Zeit ist eine erneute Änderung der Einstellung nicht möglich."
why do I have to wait seven days? I need it right away.
Hey @Zoszkar,
i could activate it for you, if you want. Could you send me your customer data (customer number, name, address and date of birth of the contract owner) via private message?
Please let me know in the article when you have sent me the data.
Regards
Zoszkar
I sent a private message
Best Regards
Hey @Zoszkar,
Regards
