CH7466CE: 5GHz network not working
Roman_Dolinsky1
Hello support,
I have the same problem as a person on this topic: https://forum.vodafone.de/t5/Internet-Ger%C3%A4te/Compal-CH7466CE-5GHz-WLAN-setzt-regelm%C3%A4%C3%9F...
Problem with CH7466CE modem
After factory reset, 5Ghz network work for 1-2 days, and after that time network is not accessible.
After last factory reset, BSSOD is 00 00 00 00 00 00 and no other device is able found that network.
5 Antworten 5
Martin59
Hello Roman_Dolinsky1,
please send me a PN with your name, address, date of birth and customer number.
Please let me know as soon as you have sent the message.
Best regards, Martin
PN was send
Martin59
Hi Roman_Dolinsky1,
if you do not mind, I will reset the complete W-LAN settings.  This will also reset the SSIDs and the W-LAN passwords to the original state.
Ok you can try. But I don't think that's help because even Factory reset don't help
Martin59
Hi Roman_Dolinsky1,
i just resest the Wifi-Settings.
