am
03.09.2019
23:15
- zuletzt bearbeitet am
04.09.2019
13:56
von
akoch
Dear Support Team,
Sorry for writing in English. I subscribed to Gigacube Max with 250GB plan. For some reason the speed is deadly slow, 2 mbits/sec. Signal strength is quite good, with 4/5 bars. I tried hard reset, changing the location of the device, etc. But no use. Also checked for updates.
Why is my internet speed so slow? Can anyone suggest what could be wrong? If I Vodafone cannot improve the speed for me, I may have to return the device.
Thanks
Dillu
Header with site added (akoch)
04.09.2019 01:22 - bearbeitet 04.09.2019 01:26
Please note that there is no minimum speed given. The speeds that can be achieved vary depending on the network quality and the number of other users that you share the overall bandwith inside one network cell.
The cell speed itself is dependent on the network technology used and the used frequencies (e.g. if it's a 4G/LTE-700+800 cell, a bandwidth of approx. 125 MBit/s is avaiable for all customers; if it's a 4G/LTE-1800+2600 cell, a bandwidth of approx. 300 MBit/s is available; if it's only a 3G/UMTS cell, you'd only have 42 MBit/s available).
If you are not satisfied with the speed -AND- within the first 30 days, you might return the device in accordance with the rules of the so called "Zufriedenheitsgarantie". Maybe it's better if you get a landline connection.
04.09.2019 08:34 - bearbeitet 04.09.2019 08:35
Do you have the slow connection only at a specific location?
Where?
And please post the following information because maybe the LTE cell is overloaded, so i can check the cell:
GigaCube Cell ID und RSRP/RSRQ/RSSI posten:
1. Browser öffnen und 192.168.8.1 eintippen (WLAN Verbindung zum Router vorausgesetzt)
2. anmelden mit Benutzername "admin" und Passwort von der Rückseite ablesen (nicht das WIFi-Passwort eingeben !)
3. oben auf Einstellungen klicken
4. links auf System klicken
5. auf Geräteinformationen klicken
6. die Cell_ID (eine Zahl) findest Du in der Mitte der Seite (je nach Browser-Ansicht)
7. Die Abfrage möglichst dann durchführen, wenn es zum Ausfall oder Störung kommt.
Kein Support via PN !!
am 04.09.2019 11:28
Thanks for replying.
Here is the cell ID: 18090754
Anything you can do to increase my internet speed is highly appreciated.
Thanks again
Dillu
am 04.09.2019 12:23
Hi dillu,
please send us per pm (click here😞
We will check it.
Have a nice day....
Thanks!
mandy_fipi
am 04.09.2019 14:09
Location should be in the middle Ulm or?
LTE site is not overloaded and have good performance.
Do you have the slow connection only at this location?
am 04.09.2019 22:24
I changed location and I placed it near a window. Still same for speed 😞
am 05.09.2019 10:03
is it possible, that you can test the simcard in a mobile?
mandy_fipi
am 05.09.2019 10:20
Thats a good idea. I can insert the sim in Iphone and check for speed.
I will reply to this message once I find the results.
Dillu
am 05.09.2019 11:24
