need help in english
Shane3in1
Hi! My internet has been out the last 24 hours.  In the log it says CHAP authentication failure.  What do I need to do to fix it?  My account number is ***.
*** @Shane3in1, personal data removed, thread moved from Gewinnspiele to DSL ***
6 Antworten 6
Mav1976
@Shane3in1, does your issue related with DSL or cable?
Moni_GK
Hello Shane3in1,
do you use DSL or cable?
Best regards
Moni^mmk
I have DSL.  Thank you for your help.
i have tried putting the setup code back into the router and it fails every time I try.  Seems if my access to the system has been messed up.
issue has been fixed.  Thank you.
Jens-K
Hi Shane3in1,
thanks for your feedback.
I'm glad you can use your DSL connection again.
As your issue has been solved, I close this thread.
Regards,
Jens
