Hotspot Flat - Login management does not work
DarioG
Hello!
There is an issue when I try to log in here: https://hotspot.vodafone.de/service/ - any time I try to access I get error 500.
The Vodafone Login I use are correct, i even reset the password.
I have been using the service for years, with some ups and downs, now I am completely cut off.
Any help would be appreciated!
RED_DUSTin
Hi @DarioG :).
Please contact us directly -> Dein Kontakt zu Vodafone and we'll help you gladly out with this issue of yours.
Best regards
BEST_DUSTin
@RED_DUSTin thanks for the answer! the chatbot doesn't speak english, and the customer care is all in german. is there any english-speaking number?
I did write an email to [email protected]
You can use a translator like DeepL to properly translate it.
Best regards
RED_DUSTin
