utopia: fw.lanattack drop
EngUserBayern
Frequent disruptions to the connections with router turning on and off.
Any solutions to this?
Thanks.
20 Antworten 20
Kieferer
Host-Legende
Host-Legende
Reddit
https://www.reddit.com/r/antivirus/comments/jy9efo/utopia_dns_hijacker/
I have had the same problem with Vodaphone router. It's super annoying.
I read this blogpost https://usefulvid.com/vodafone-station-wlan-probleme-geloest-2021-bilder-video/ which suggests 2 solutions.: (A) Get a different router (no from Vodaphone) or (B) disabled the 5GHz network.
I have disabled the 5GHz network (B) but it doesn't seem to improve.
Another solution that I tried in the past (not related to the blogpost), was to change the SSID (Wifi name). The logic behind that, was that if I was actually under a WANATTACK I won't get found. Not sure if it makes sense. It actually worked for a while (a few weeks) but I am not sure how optimal is to change the SSID name every once in a while.
I welcome other solutions. otherwise, I will start thinking about buying a new router.
*** Vodaphone
Antworten
ERFD
Hello EngUserBayern,
the disconnections on your connection are identical in time to this log? Does this affect all appliances in the home? Are there no more dropouts when the firewall is inactive? Please answer the following questions.
Best regards Fred
Apologies for the VERY late reply. Just got time to come around to this.
the disconnections on your connection are identical in time to this log? Yes, that is correct.
Does this affect all appliances in the home? True again.
Are there no more dropouts when the firewall is inactive? I haven't tried this; is it safe to turn off the Firewall?!
Please answer the following questions. Answers sent as a Private Message.
Many Thanks.
...is it safe to turn off the Firewall?!
Only when you like Malware, Viruses, Spyware etc in your Net
Never ever switch off the FW. You will be vulnerable to any attacks from the WAN Net - all doors would be open - everybody could harm you.
A SPI Firewall allows only traffic what you are requesting - appliances, web etc. - and blocks anything going in what has been not requested by you. Basicaly requested LAN to WAN (internet) traffic goes through, Unsoliceted WAN trafic is blocked.
I am dumbstruck that suggestion came from a mod!
Hello utopia,
I am very sorry that your connection is down.
In order to check your connection, please send me your details (customer number, address, name and date of birth) in a private message.
Then report briefly in the post when you have sent the message.
Many greetings
Jana
Detail sent. Thanks.
well,  you send us your customer number, but their are much more infos left (or didnt i found them?) - could you send them to me please via private message? 🙂
Regards
Private Message sent.
Sincere thanks.
