am 04.06.2021 00:32
am 04.06.2021 14:04
there is an interferer radiating on our upstreams, causing the error rate to be too high. I have initiated the fault clearance and if it was successful, you will receive an SMS from us.
Regards
Wallace
am 04.06.2021 11:03
Hi Jega,
I like to look at your connection. Send me your customer data (name, address, customer number, birthday) in a private message and then let me know here that you have sent the data.
Regards
Wallace
am 04.06.2021 12:00
am 04.06.2021 14:04
Regards
Wallace
am 12.06.2021 12:07
Hi Wallace. Thank you for following this up. I gave it a week to see if it makes a difference. The restarting behaviour got better but it still happens occassionally (about once every few days now rather than every few hours).
am 14.06.2021 10:38
Hello JegaT,
what are your current speed test values via LAN? Do you notice when it breaks down that the connection is particularly slow and the values are not correct?
Many greetings
Jana
am 14.06.2021 12:40
Hi Jana,
The most recent test I ran (a few minutes ago) gave a ping of 9 ms, download speed of 257.67 Mbps and an upload speed of 27.46 Mbps. I do not notice a slowdown when the router suddenly restarts, so I suspect the router restarts are unrelated to the speed. Unfortunately, I also cannot see a pattern to the restarts.
Many thanks,
Jega
am 15.06.2021 07:46
Hello JegaT,
the line currently looks quite good, when did you have the last break?
Many greetings
Jana
