am 05.11.2021 22:10
Dear support,
My cable internet connection is very unstable since 2-3 weeks.
I work from home and some day it is impossible to participate to conference calls.
Upload speeds are sometimes lower than 1 Mbit.. Specially from 5pm.
I suppose that there is a problem with the line.
I tried several solutions.
Vielen Dank for your support !
Jordan
am 06.11.2021 18:20
It is getting worse everyday with impossibility to even play games without disconnection...
There are picks under 1mbps randomly..
am 06.11.2021 19:24
I have identical issues with my Vodafone Kabel lasting since May this year, see https://forum.vodafone.de/t5/St%C3%B6rungsmeldungen-Internet-TV/St%C3%A4ndig-Verbindungsverlust-f%C3...
Unfortunately Vodafone can't or doesn't want to fix the issue. I wrote to this boards as my last try to get it resolved, but still didn't get an answer. At this point, I think I'm going to have to change the internet operator.
You can find information about extaordinary contract termination, in case of non fulfiled obligations from service priovider here: https://www.verbraucherzentrale.nrw/sites/default/files/2018-10/VZNRW_Bandbreite-Checkliste.pdf
It's in German, but you can easily translate it using google translate.
am 07.11.2021 21:59
I pay 84.24€/month (just internet) for this ?!
Every 3 month there is a problem since the beginning. I have never seen that in any country.
The 1000/50 is fake here, I will probably go back to real DSL...
am 08.11.2021 09:39
Update:
I did a lot of testing and I realized that I have very low speeds with my private Fritzbox 6660. I installed again the Vodafone 6591 (same problem during the day). I did a factory reset of 6591 and I had an update from OS 7.21 to OS 7.27 during the night. Since then, the 6591 show only "übertragung der Betriebsparameter und Registrierung an der CMTS" in Kabel-Informationen. No internet with 6591. I had to switch to my 6660 which is working (still very unstable) but better than nothing at all for home office.
am 09.11.2021 12:22
Hello Elek,
I would be happy to take a closer look at your connection. Please connect our device.
Best regards
Nancy
am 09.11.2021 16:05
Hello Nancy
The modem is connected since 5am this morning. Thats one of the problem, your modem does not connect to internet anymore
Best Regards
am 11.11.2021 13:01
Ok, now I can't even work at all from home during the day.
It is becoming URGENT !!!
Can I have a technician coming ? It can NOT wait any longer.
am 12.11.2021 12:58
Hello Elek,
if a issue is on your site, you have to pay for the technician. We would like to prevent this for you.
Did your cablerouter have the same signal in the menu? Are all cable ok?
Regards
Jens
am 12.11.2021 13:14
Hello
The termin with technician is already set for this afternoon, let's see.
I already tried to replace and check all cables, and did severeal different restart.
With the big price I pay each month (83+€ per month JUST for internet), if I have any additional cost, I will just go away and take a realiale DSL 100/40 connection with a competitor.
I need stability for my work at home, I have problems with this cable since always (3 years).
Best regards
Jordan
