Upload very low and unstable internet
Elek
Digitalisierer
Digitalisierer
Dear support,
My cable internet connection is very unstable since 2-3 weeks.
I work from home and some day it is impossible to participate to conference calls.
Upload speeds are sometimes lower than 1 Mbit.. Specially from 5pm.
I suppose that there is a problem with the line.
I tried several solutions.
  • In welchem Bundesland wohnst Du?
    • Hamburg
    • Red Internet & Phone Business 1000 Cable
    • FRITZ!Box 6591 Cable
    • I use the Leih-Gerät but I also tried with my own FRITZ!Box 6660 Cable that I bought myself > same problem
  • Welcher Fehler tritt auf? (Geschwindigkeit zu gering; Packetloss) Schick dazu auch Screenshots von Speedtests (mit Datum und Uhrzeit) und Tracerts/ Pingplotter-Messungen bei Packetloss oder Ping-Problemen
    • LAN. Also tried with WLAN with laptop = same problem
    • Chrome, Edge, Firefox, same problem
    • Windows 10. Also tried with Android with smartphone
    • Beginning of October
  • Welche Maßnahmen wurden durch die Störungshotline (erreichbar unter 0800-5266625) durchgeführt?
    • Did not try the hotline as I don't speak good enough german :'(
Vielen Dank for your support !
Jordan
12 Antworten 12
Wallace
Ex-Moderator:in
Ex-Moderator:in
was the technician able to do anything?
Regards
Wallace
Elek
Digitalisierer
Digitalisierer
Hello
The technician said that I don't have a good reception on my line and this triggers issues and will be even worse if more people get cable in my building.
Thus I easily decided to resiliate my contract and go for VDSL 100. I can't live any longer with cable.
Funny thing, since I launched the resiliation process, now I guess it's working again (no longer lags).
I did not even try with vodafone box because I don't care anymore, this cable is a joke, I am just leaving.
Have a nice day and thank you for the support
Ex-Moderator:in
Ex-Moderator:in
Hello Elek,
as you decided to cancel the contract I will close your thread now.
Kind regards,
