Unstable internet connection
Krzysztof2022
I have  a problem with unstable internet connecion.
Unstable and disconection on wifi and LAN with ping varies like on screen.Bez nazwy-1.jpgBez nazwy-2.jpg
pRo-Marco
Hi Krzysztof2022,
like on your screenshots the problem begins with the connection between your device and the router. Did you check another device connected through LAN?
Kind regards
