am 06.10.2020 14:22
Hello,
While connected to a Vodafone internet if I turn on my company's private VPN the speed drops drastically. I already talked to my company's tech ops team and it seems like there are no issues on their end.
Can you help me with this?
I first asked this here but no one answered it.
Thanks,
Mustafa.
am 07.10.2020 15:48
Hello MustafaMutlu,
which speeds can you reach over a VPN and which without the VPN?
Many greetings, Martin
am 09.10.2020 15:53
am 12.10.2020 11:39
Hello MustafaMutlu,
I would like to take a closer look.
Please send me your name, address, date of birth and customer number by PN .
Please contact us again afterwards.
Best regards, Martin
am 13.10.2020 10:48
Hello MustafaMutlu,
were the speed tests carried out via LAN or W-LAN?
am 13.10.2020 13:26
I did it over WLAN
am 14.10.2020 10:37
Hello MustafaMutlu,
what do the results look like when you run the tests over a LAN connection?
am 14.10.2020 10:43
Hey Martin,
I can't both connect to VPN and do the test over LAN because my company's laptop is a Macbook Pro without ethernet port and I unfortunately don't have a dongle for that..
Also, like I mentioned previously when I turn off the VPN I get 200 MBit over WLAN which is great becaue my internet plan is for 200 MBit so it's a good speed. When I turn on the VPN seconds after doing the first test, I get much lower speed, around 2 MBit also on WLAN.
So both tests are on WLAN:
VPN on: 2Mbit download
VPN off: 200 Mbit download
Do we need to do more tests with LAN to see if speed improves when VPN is on because of the cable?
Being able to reach 200 MBit on WLAN when the VPN is turned off shows the speed isssue is not throttled by the WLAN connection.
What do you think?
Thanks for helping,
Mustafa
am 15.10.2020 11:58
Hello MustafaMutlu,
which VPN service do you use?
Have you ever looked at which server your VPN connection goes through? If it is geographically far away, it can affect the speed.
Many greetings, Manu
am 29.10.2020 15:53
The location of the VPN server is Frankfurt.
I don't think location is the issue, because when the speed is slow (2 MBit) I restart my router and after I restart my router I get decent speed (being 50 MBit).
So I don't know what causes this slow down. I also don't think another connection on the same router is causing the issue becaue when VPN is 2MBit I log off from VPN and the speed fine. It's only the VPN that is affected by the issue..
