am 03.06.2022 23:01
I have problem with the internet connection. I just moved to Germany and got a new Vodafone contract on the 25.05. The new router (Sagemcom FAST 5460) arrived 4 days ago. I followed all of the instruction as described and repeated them multiple times, but still could not get any internet so far. I tried also multiple times following the troubleshooting with TOBI on the Vodafone website, but this also didn't help. On the router the power LED and WIFI LED are always on, but the Internet LED is always just blinking. I have three plug connection to the wall and I made sure that coaxial cable is connected correctly and to the correct socket. It's worth mentioning that the buliding to which I moved is completely new and I am a first tenant, so I am wondering if it is maybe necessary that a technician has to come first and hook up the connection. All the help is appreciated. Thank you.
am 08.06.2022 18:19
Hi Anett,
Today the technician came to my appartment and solved the problem. Now everything works.
Thank you very much for your help.
Best,
Tomislav
am 04.06.2022 16:43
Basically you can follow this thread.
am 05.06.2022 11:02
Thanks, unfortunately it doesn't help me.
am 05.06.2022 11:05
Some additional info: When I go to my router settings under the Device Information tab- it says Networka accsess: Not Allowed. The status of the internet always says: In Process.
am 05.06.2022 12:08
Hello tomtomtom2,
I would like to check what exactly is the problem. Please send me your data (name, customer number, address and date of birth) via PN .
Then contact me again here in the post.
Best Regards
Anett
am 05.06.2022 12:19
Hi Anett,
I sent you a PM. Thank you for checking it out.
am 05.06.2022 13:23
Thank you for your message.
It looks like the device can't pull the data for the contract, so I'll have to get you a technician. The phone number ***5108 is correct? The technician will contact you via this number.
Can you provide access to the house system?
Regards
Anett
am 05.06.2022 13:28
Hi Anett,
Yes, the phone number is correct. Yes, I can also provide access to the house system.
Thank you very much.
Best,
Tomislav
am 05.06.2022 14:35
Hello tomtom2,
I have instructed the technician and he will contact you to arrange an appointment.
Feel free to give me feedback if everything worked out.
Best Regards
Anett
am 05.06.2022 14:39
Ok, will do. Thank you!
