am 24.08.2024 17:10
Guten Tag.
Ich habe seit einer Woche Probleme mit meinem Netz.
Der Router Startet sich mehrmals am tag auf unterschiedlichen Zeiten neu. Manchmal auch mehrmals am Stück.
Im Ereignisprotokoll user_wifilog steht:
2024-08-24 16:53:08 log.warn [88000101]: 4,2024-08-24 16:52:54 k2_SSID Device Associated.WG-MAC=2C:71:FF:00:00:00;SSID="Vodafone-E85C";On Channel=100.
2024-08-24 16:53:58 log.warn [88000102]: 1,2024-08-24 16:53:58 k1_SSID Device BE:7E:3A:36:50:1B disconnected from SSID Device.WiFi.SSID.1 REASON-CODE=8.
2024-08-24 16:54:00 log.warn [88000101]: 5,2024-08-24 16:52:54 k1_SSID Device Associated.WG-MAC=BE:7E:3A:00:00:00;SSID="Vodafone-E85C";On Channel=11.
2024-08-24 16:54:08 log.warn [88000101]: 11,2024-08-24 16:54:00 k2_SSID Device Associated.WG-MAC=BE:7E:3A:00:00:00;SSID="Vodafone-E85C";On Channel=100.
2024-08-24 16:54:23 log.info [88000301]: 1,2024-08-24 16:54:23 k1_SSID Configuration Changed. ACS Setting Channel = 11.
2024-08-24 16:54:23 log.info [88000301]: 2,2024-08-24 16:54:23 k2_SSID Configuration Changed. ACS Setting Channel = 100.
2024-08-24 17:01:53 log.info [88000301]: 2,2024-08-24 17:01:53 k2_SSID Configuration Changed. ACS Setting Channel = 52.
2024-08-24 17:02:41 log.warn [88000101]: 1,2024-08-24 17:02:41 k1_SSID Device Associated.WG-MAC=BE:7E:3A:00:00:00;SSID="Vodafone-E85C";On Channel=1.
2024-08-24 17:03:05 log.info [88000301]: 5,2024-08-24 17:03:05 k1_SSID Configuration Changed. ACS Setting Channel = 1.
2024-08-24 17:03:32 log.warn [88000205]: 3,2024-08-24 16:52:47 Interface Reset ,Link is Up.
2024-08-24 17:03:37 log.warn [88000102]: 1,2024-08-24 17:03:37 k1_SSID Device BE:7E:3A:36:50:1B disconnected from SSID Device.WiFi.SSID.1 REASON-CODE=1.
2024-08-24 17:03:43 log.warn [88000101]: 11,2024-08-24 16:52:54 k1_SSID Device BE:7E:3A:00:00:00 Associated to 2.4GHz.
2024-08-24 17:03:43 log.warn [88000101]: 6,2024-08-24 17:03:32 k1_SSID Device Associated.WG-MAC=BE:7E:3A:00:00:00;SSID="Vodafone-E85C";On Channel=6.
2024-08-24 17:03:50 log.info [88000301]: 1,2024-08-24 17:03:50 k1_SSID Configuration Changed. BandSteering is Disabled.
2024-08-24 17:04:48 log.info [88000301]: 3,2024-08-24 17:01:53 k1_SSID Configuration Changed. ACS Setting Channel = 6.
2024-08-24 17:04:48 log.info [88000301]: 6,2024-08-24 17:02:09 k2_SSID Configuration Changed. ACS Setting Channel = 112.
2024-08-24 17:06:43 log.warn [88000102]: 2,2024-08-24 17:04:55 k1_SSID Device 2C:71:FF:D5:55:26 disconnected from SSID Device.WiFi.SSID.1 REASON-CODE=8.
2024-08-24 17:06:46 log.warn [88000101]: 15,2024-08-24 17:04:46 k1_SSID Device 2C:71:FF:00:00:00 Associated to 2.4GHz.
2024-08-24 17:06:46 log.warn [88000101]: 15,2024-08-24 17:04:46 k1_SSID Device Associated.WG-MAC=2C:71:FF:00:00:00;SSID="Vodafone-E85C";On Channel=6.
2024-08-24 17:07:32 log.warn [88000101]: 14,2024-08-24 16:54:00 k2_SSID Device BE:7E:3A:00:00:00 Associated to 5GHz.
2024-08-24 17:07:32 log.warn [88000101]: 19,2024-08-24 17:06:52 k2_SSID Device Associated.WG-MAC=BE:7E:3A:00:00:00;SSID="Vodafone-E85C";On Channel=112.
2024-08-24 17:07:32 log.warn [88000101]: 8,2024-08-24 16:52:54 k2_SSID Device 2C:71:FF:00:00:00 Associated to 5GHz.
2024-08-24 17:07:32 log.warn [88000101]: 19,2024-08-24 17:06:46 k2_SSID Device Associated.WG-MAC=2C:71:FF:00:00:00;SSID="Vodafone-E85C";On Channel=112.
In der Firewall steht:
2024-08-24 17:03:54 FwLog.crit [10000005]: 90,2024-02-09 23:31:17 UTOPIA: FIREWALL RESTART
2024-08-24 17:03:54 FwLog.crit [10000005]: 90,2024-02-09 23:31:17 UTOPIA: FIREWALL START
Wie gesagt passiert das mehrmals am tag seit einer Woche.
am 24.08.2024 19:24
Bei dir liegt ein Rückwegstörer vor, melde das mal der Hotline.
am 24.08.2024 17:19
Poste mal ein Screenshot der Signalwerte des Routers. Um sich die Signalwerte anzeigen zu lassen, gehst du wie folgt vor, Benutzeroberfläche öffnen > Oben rechts Status&Hilfe anklicken >
Danach links den Menüpunkt Docsis-Status öffnen, dort werden die Signalwerte angezeigt.
am 24.08.2024 17:44
am 24.08.2024 19:24
am 26.08.2024 16:24
Ich habe einige Sachen selber probiert die als Lösungsmöglichkeiten für Rückwegstörungen angegeben sind und habe seit 2 Tagen keinen einzigen Ausfall gehabt. Vielen Dank für die Hilfe. Ich hoffe das es so bleibt.
am 26.08.2024 16:25
