Fritzbox 6660 cable is stuck at "Establishing connection ..."
user42345
I replaced my vodafone station router with a fritzbox 6660 (given by vodafone). I followed the instructions to setup and the cable connection is stuck saying "Establishing connecion". I know I have an internet connection because I unplugged it attacched the voddafone station router and connection worked.
why is it nor working with Fritzbox 6660. Should I be patient and wait more than an hour for connection to establish, that does not seem reasonable. I also tried to turn it off and on again unplugging both the cable connection and power. But nothing worked. WLAN is working fine. Internet connection is not (Power light keeps flashing on and off).
Hello user42345,
the Fritzbox should be online a few minutes after you connect it with the antenna socket. Is the Fritzbox and Homebox option shown in the customer portal? Do you use the same cables for the router and the Fritzbox? Please send the details from the thread Alles rund um Störungsmeldungen so we have some more details.
Kind regards,
