Blinking red light
qwerty12345
Hello. I received Vodafone station 6 (a cable contract) last week and installed it according to a guidebook, but the red light keeps blinking all day. Could you give me English support?
Hi Tina,
Thanks to your support, I can use the internet!
Thank you so much!
7 Antworten 7
Tina
Hello qwerty,
welcome to our community. For a closer look send me the following informations in a private message:
full name
date of birth
address
customer number
I will probably hire a technician to do the install. For that I need your phone number.
Write a short reply here afterwards.
Best regards
Tina
Dear Tina,
I sent the necessary information to you.
Tina
Thank you. You have connected the cable router according to the instructions? Does the wall socket have 2, 3 or 4 connections? If a technician is needed for the installation, I need a phone number (national).
I have connected the cable router according to the instruction. The wall socket has 2 connections.
When I pushed a reset button, all lights kept blinking white. But, only the internet light flashed white and red.
Unfortunately, I don't have a German number yet.
Tina
Thank you. I am forwarding a ticket to our specialist department. I will leave your phone number. Please leave the cable router connected.
Best regards
Tina
Hi Tina,
Thank you so much!
Tina
You're welcome . As your request is solved, I will close this thread now.
