1 GB network
1GB
Youngster
Youngster
Hello, I am having issues with my network. I pay for 1 GB but I only get up to 400 Mbs. Maybe I get 100 Mbs. It has recently started happening. I've had for 3 months now and issue just started. I've reset the modem twice already.
seelo2010
Sei doch bitte so lieb und poste einmal deine Signalpegel.
Diese findest Du in deinem Router, bei einer Fritzbox wäre dieser unter Internet - Kabel-Informationen und dort der zweite Reiter zu finden.
Dann können wir schon einmal ggf. HF Störungen erkennen.
Vorzugsweise die Signalpegel als Screenshot hochladen.
Grob zur Orientierung kannst du folgende Tablette nehmen, diese taucht hier hin und wieder auf. Quelle Meister Voda
https://www.vodafonekabelforum.de/download/file.php?id=646
Eng. version
Please be so kind as to post your signal levels.
You can find these in your router. On a FRITZ!Box, for example, they are located under Internet → Cable Information, and then on the second tab.
This will allow us to identify any potential RF (high frequency) signal issues right away.
Preferably, upload the signal levels as a screenshot.
As a rough guide, you can use the following table, which appears here from time to time.
Source: Meister Voda
reneromann
But you are not solely using WiFi for speed tests and surfing...
