Not avaiable internet - DOCSIS offline
PDM
First of all, I'm afraid that couldn't speak German language because I'm foreigner who living in Bad Soden(ZIP 65812)
Today, I followed guide line and installed rauter without any problem.
Unfortunately there is no internet connection. this maybe due to DOCSIS offline signal as attached.
Internet/WIFI/Power signal always shows white light without blinking.
I suspected the DSL would be root-cause in this problem.
could you please check my status and let me know how to solve this problem?
  • Which contract do you have?  (e.g. Internet + Telephone 100)  Giga Home 100 Cable
  • Which modem/router do you use? (e.g. Hitron) Vodafone Station
  • Are you using a rental device from us or do you have your own device?  : Rental device
  • What error occurs?  : No Internet (DOCSIS offline)
  • How  is your device connected to the modem ? : LAN/WLAN
  • Which browser do you normally use?  : Chrome
  • Which operating system do you have on your computer?  : Windows 10
  • Start  and period of disruption  : since 21st June (Continually)
RobertP
perform a factory reset:  press and hold reset for 20 seconds
RobertP
