DOT (DNS over TLS) BLOCKED by EasyBox 805 with DISABLED Firewall
ConradS
Why is Vodafone blocking UDP/853 queries??
With or without EasyBox 805 firewall disabled, it does not matter, this service is blocked. Plus, the firewall is meant to block incoming traffic, not outgoing. Why?
This behaviour is messing with our democratic rights, our freedom to choose whatever service we want to use. I thought this was Europe not China.
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34442 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34491 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34340 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34834 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=35143 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34510 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34963 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34315 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34426 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=35012 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34788 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34790 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=35030 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=35429 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=35055 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34792 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34772 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=149.112.112.112 PROTO=TCP SPT=34548 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=35189 DPT=443 MARK=0x3 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34508 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=35106 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=94.140.14.141 PROTO=TCP SPT=34634 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=34563 DPT=853 MARK=0x1 DROP
[WARNING][Firewall] 05-19-2022 19:11:00 src=192.168.2.2 DST=9.9.9.9 PROTO=TCP SPT=35350 DPT=853 MARK=0x1 DROP
2 Antworten 2
ConradS
Why is the WiFiScan flood the Eventslog when both WiFi services (2.4 and 5) are turned off???
[WARNING][LAN] 05-19-2022 16:59:59 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:59 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:57 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:57 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:56 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:56 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:55 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:55 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:54 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:54 WiFiScan failed on 2.4G! ret is 1.
[INFO][System] 05-19-2022 16:59:54 FSM---- Switch to Connect State.
[WARNING][LAN] 05-19-2022 16:59:53 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:53 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:52 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:52 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:51 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:51 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:50 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:50 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:49 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:49 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:48 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:48 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:47 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:47 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:46 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:46 WiFiScan failed on 5G! ret is 1.
[INFO][System] 05-19-2022 16:59:45 FSM---- Switch to Connect State.
[WARNING][LAN] 05-19-2022 16:59:45 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:45 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:44 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:43 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:42 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:42 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:41 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:41 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:40 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:40 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:39 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:39 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:38 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:38 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:37 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:37 WiFiScan failed on 5G! ret is 1.
[INFO][System] 05-19-2022 16:59:37 FSM---- Switch to Connect State.
[WARNING][LAN] 05-19-2022 16:59:36 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:36 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:35 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:35 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:34 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:34 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:33 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:33 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:32 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:32 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:31 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:31 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:30 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:30 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:29 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:29 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:28 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:27 WiFiScan failed on 2.4G! ret is 1.
[INFO][System] 05-19-2022 16:59:27 FSM---- Switch to Connect State.
[WARNING][LAN] 05-19-2022 16:59:26 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:26 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:25 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:25 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:24 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:24 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:23 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:23 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:22 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:22 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:21 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:21 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:20 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:20 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:19 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:19 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:18 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:18 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:17 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:17 WiFiScan failed on 2.4G! ret is 1.
[INFO][System] 05-19-2022 16:59:17 FSM---- Switch to Connect State.
[WARNING][LAN] 05-19-2022 16:59:16 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:16 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:15 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:15 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:14 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:13 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:12 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:12 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:11 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:11 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:10 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:10 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:09 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:09 WiFiScan failed on 2.4G! ret is 1.
[INFO][System] 05-19-2022 16:59:09 FSM---- Switch to Connect State.
[WARNING][LAN] 05-19-2022 16:59:08 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:08 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:07 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:07 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:06 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:06 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:05 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:05 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:04 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:04 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:03 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:03 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:02 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:01 WiFiScan failed on 2.4G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:00 WiFiScan failed on 5G! ret is 1.
[WARNING][LAN] 05-19-2022 16:59:00 WiFiScan failed on 2.4G! ret is 1.
Andre
Hey ConradS,
as far as i know we don't support dns over ssl/tls with our dsl landlines.
You can use a different dns server (as long as your router offers this setting) , but not encrypted.
The easybox is designed as an easy device for beginners.
For advanced users , we are offering different avm fritzbox models.
Cheers,
Andre
