Problems ordering GigaMobil Young XL with a Dutch IBAN
Rancid
Rookie
Rookie
Hello, I am unable to buy the GigaMobil young XL plan because I don't have a german IBAN yet. Is there any workaround to that? Thanks!
2 Antworten 2
Mav1976
Hi @Rancid,
I'm not sure but as far I can remember is online only a German IBAN possible. Do you have the possibility to use a German IBAN by a friend for short time?
It should be possible to change your bank data afterwards with InfoDok 230 to your Dutch IBAN.
Or you can go into a VF store to sign a contract. Maybe it's possible there to accept the Dutch IBAN at the first go. But be aware that your haven't a right of revocation after signing of a contract there.
emily2505
Hi!
The best option is to contact our support team so they can check whether an alternative ordering process is possible for your case. You can also visit a Vodafone shop with your documents, where the team can review the available options together with you.
We hope you'll be able to join us soon! 🚀📱https://vod.af/VodafoneWhatsAppHilfe
