Mehr? Entdecke unsere digitalen Lösungen und nutz sie!
Störung? Nutz unsere Hilfe bei Störung!
TOBi Jetzt mit TOBi chatten
change to lower tariff
tshui
I am currently having "Red Internet & Phone 1000 Cable" tariff. As per stated the contract, I am eligible to change to a lower tariff at the 7th month. Please if you would help with the change to "Red Internet & Phone 50 Cable".
Many thanks.
Stephan
Hi tshui,
thanks for your pm.
The change to Red Internet & Phone 50 Cable will be effective on 9 May 2021. To this date you'll get an extra confirmation and you can see the new tariff in your customer portal.
Regards
Stephan
9 Antworten 9
Lars
Hi tshui,
which German state are you from?
Best regards
Lars
tshui
Hi Lars,
I am located in Munich.
Thanks.
Best regards,
Shin Hui
Stephan
Hi tshui,
then please send me a private message with the following information:
your name
your address
date of birth
your customer number
the link of this thread
Please reply here when you have sent the private message.
Regards
Stephan
tshui
Hi Stephan,
Private message sent with the information.
Can I double check the price after switching.
Thanks.
Best regards,
Shin Hui
Stephan
Hi tshui,
thanks for your pm.
Regards
Stephan
tshui
Thanks Stephan,
Just want to let you know that I have not seen or get extra confirmation on the change.
May I double check whether all good for the change. Thanks for your support.
Best regards,
Shin Hui
Thomas
Hi tshui,
as already written, the changeover will take place on 09.05. and only then will the confirmation be sent. So just have a little patience.
Regards
Thomas
tshui
Thank you. I received the letter stating the tariff had been change. In the paper, It say that I have the right to revoke this contract within 14 days without giving a reason. Can I clarify if I choose to revoke, is it refer only to the change to 50 cable tariff... OR it means the whole contact originally signed up will be terminated and I will not be bound to the remaining 18 months ?
Thomas
Hi tshui,
only the change can be revoked.
Regards
Thomas
