WiFi does not work
artemvodovatov
I have vodafone station Vodafone CGA6444VF
WiFi stopped work. Lights for telephone, internet and power are blue, but I can not turn on WiFi. Restart of device and change of plug does not help
6 Antworten 6
Try a factory reset. To do this, hold down the reset button for at least 20 seconds.
Best regards Kurt
Gelöschter User
Nicht anwendbar
The "Vodafone Station" has got a hardware button to switch WIFI on/off. Have you tried this one?
PS. Perhaps you have to try it several times until it works.
yes, I tried both and hold this button. After single push - nothing happened. If I am holding it - LED just blinking. but after all WIFI anyway down
Press and hold reset button on the back of the router for at least 20 seconds using a paperclip
tried to do this, but the same issue
Gelöschter User
Nicht anwendbar
If the router is broken, it has to be replaced. Please contact the customer service via hotline (0800/1721212), TOBI via WhatsApp or use the contact form.
vod.af/kontakt
