No external access to my PC
Yoshevski
Hi I have a Cable connection with a Vodafone router TG34..DE.
In the router firewall I had set ports 80 and 443 to forward to my PC, as well my PC is having reserved IP.
I’ve tried to setup access using ddclient with a domain (using ipv4 and ipv6)
I’ve tried to access directly by my external IPv4
I’ve tried to access from browser using IPv6 as well
Nothing seems to work, although the nginx is set to listen to ipv4 and 6 on ports 80 and 443
Does anyone have any suggestion how can I fix this?
Thanks
6 Antworten 6
J0hann
Hallo @Yoshevski,
please contact our customer service vie these contact channels and let them have a look at your provisioning method.
The service on WhatsApp will help in English.
BR J0hann
RobertP
are IPv6 privacy extensions disabled on your webserver?
Yes, the IPv6 is completely allowed.
I had even tried to turn off the firewall on the router and on the pc, but that didn’t helped as well.
It seems like the router is not make any redirects.
Hi @Yoshevski,
We will be happy to provide you with a detailed overview. ❤️ So please be so kind and use one of the following contact options (e.g. WhatsApp) and we will be happy to take care of your request.
Kind regards
R4mona
and IPv6 privacy extension are disabled in network adapter settings?
Hi @R4mona ,
I gave it up, it simply doesn't work. I have tried to turn off the firewall on the router, as well the computer was set without firewall, then I did try to add port forwarding rules etc.. but simply it doesn't work.
@RobertP when I try to access using IPv6 from the browser, I'm only able to access from my cellphone which is on a completely different mobile network. From any other computer / device and network it doesn't work.
This should be very simple e.g plug and play but it doesn't work. So as I wrote, I just gave it up.
Nor IPv4 nor IPv6 works.
