Android apps not working on WiFi
sushantsoni1
My problem is exactly the same as in this post.
https://ipv6.google.com is not loading at all and some of the apps also are not loading. Everything works fine on mobile data.
2 Antworten 2
Moni_GK
Hello sushantsoni1,
which apps does it affect exactly on which phone?
In which state do you live?
Greetings Moni
imfrhn
I am facing the exact same problem. Did you find the solution?
Thanks
