New Cable connection does not work
rihby20
I recently switched my internet plan and received a new modem from Vodafone but after connecting the cable, the modem is not getting signal and there is no internet connectivity. I would be thankful if you could fix this problem at the earliest.
Regards,
Rihby
Torsten
You post here on the DSL board, i.e. internet over the telephone line. Your report sounds more like a cable router, because with a DSL router you would have to enter the MIC from the order confirmation so that it can log in.
What kind of technology is it with you - DSL over the telephone line or Internet over the TV cable?
2 Antworten 2
Torsten
Since the solution has been marked here, a lock is now on it.
