What cable for Kabel?
kfrm
not sure i'm in the right sub-forum, but I'm sure someone knows this; I'd need a longer cable to be able to place my modem higher above ground in the opposite end of the livingroom in order to get better WIFI coverage in the whole flat. Can Vodafon supply a longer cable? If not, can somebody post a link (conrad, amazon, whatever) to the appropriate cable type?
Thanks in advance!
Hello,
the following modem cable would be suitable for what you are looking for:
https://www.amazon.de/Axing-MAK-750-80-geschirmtes-Koaxialkabel-Wei%C3%9F/dp/B003HLR5VG?th=1
or
https://www.amazon.de/Goobay-70644-Satellitenkabel-F-Stecker-Receiver-Wei%C3%9F/dp/B07GCR76RR
The second cable has better shielding. Due to the higher shielding, however, this is not as flexible as the first.
Best regards Kurt
kfrm
thanks!
ERFD
Hello kfrm,
could you bridge the height with another cable?
Greetings Fred
