Very unstable Internet cable 1000
Elek
Digitalisierer
Digitalisierer
Dear support,
My cable internet connection is very unstable but never at Max/acceptable speed.
I work from home and some day it is impossible to participate to conference calls. Also streaming via Twitch is for me completely impossible: Download and upload speeds are sometimes lower than 1 Mbit..
I never complained before I had to work from home. But now it is becoming a big problem for me.
I tried several solutions since months without success:
- change of modem
- change of cable location (1 in dinner romm, 1 in bedroom)
- test on more than 5 different computers + several other device (smartphones)
- factory reset of the modem etc..
I am convinced that there is a problem with the line or installation of the cable im my building.
  • In welchem Bundesland wohnst Du?
    • Hamburg
    • Red Internet & Phone Business 1000 Cable
    • FRITZ!Box 6591 Cable
    • I use the Leih-Gerät but I also tried with my own FRITZ!Box 6660 Cable that I bought myself > same problem
  • Welcher Fehler tritt auf? (Geschwindigkeit zu gering; Packetloss) Schick dazu auch Screenshots von Speedtests (mit Datum und Uhrzeit) und Tracerts/ Pingplotter-Messungen bei Packetloss oder Ping-Problemen
  • Speedtest shows Vodafone DSL since I did a factory reset of the modem. But it does not change the usual speeds. Even my other modem 6660 shows similar results.
    • LAN. Also tried with WLAN with laptop = same problem
    • Chrome, Edge, Firefox, same problem
    • Windows 10. Also tried with Android with smartphone
    • Always had this problem
  • Welche Maßnahmen wurden durch die Störungshotline (erreichbar unter 0800-5266625) durchgeführt?
    • Did not try the hotline as I don't speak good enough german :'(
Vielen Dank for your support !
Jordan
10 Antworten 10
Elek
Digitalisierer
Digitalisierer
Hello Moni
Ok I understand thank you very much !
It is indeed working well now ! We can definitely close the topic then 🙂
