Kabel Modem Red Light Flashing
AtillaS
Hello, I have a problem with my internet. I’ve already called the customer service. Unfortunately, they are not allowed to speak english. I need to fix the problem since I’m working from home.
I'm using Kabel Modem. All lights are okay except internet one ( flashing red ).
Thanks in advance.
Hello AtillaS,
which router do you use? Do you have a new contract or did the connection work already? In which federal state do you live?
Kind regards,
Hello AtillaS,
Kind regards,
